Are you guys just cruising around the grounds or actually entering into events?
I don't think we had many takers, maybe 4-5 Skylines, not cruising, parking in a designated area in the park (not sure where at this stage). Entry is free for up to two adults and two children in same car. Check the ACT thread and find out if its too late to enter if you're interested.
  • Replies 57
bloody hell!!!!
worlds longest weekend!
well, spotted a few of you SAUers and Charlie at the last minute at Hungry Jacks!
Oh, Im in the car on works lap top hehehehehe
got over an hour till I get in.
Not really burn rubber one entered go to whoa, and two entered dyno I think that wide body GTR won a dyno class!!
Where a lot more imports there and a turbo datto with SR20 in it did a awesome burnout on sunday :P Sounded soooo good!!
OMG did anyone see that black holden ute (mr psi) at dyno cell did 1900 horsepower and had two massive truck turbos hanging off the side of it....thats insane
I love the Nats! :P
P.S Theres pics in ACT thread...
that holden that did the 1900 blew its drive shafts. so it couldnt do his 2 other runs to get the average doh
Unigroup tuned the 6cyl winner and the 4 cyl winner, Go Yavuz!!!
Ive got about 100 photos on my camera, yet I have lost my USB cable :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
