  • Replies 66
Here's the joke I was too pissy to tell :dry:
Far away in the tropical waters of the Caribbean, two prawns were swimming around in the sea - one called Justin and the other called Christian. The prawns were constantly being harassed and threatened by sharks that patrolled the area. Finally one day Justin said to Christian, "I'm bored and frustrated at being a prawn, I wish I was a shark, then I wouldn't have any worries about being eaten..."
Just as Justin had his mind firmly on becoming a predator, a mysterious cod appears and says, "Your wish is granted", and lo and behold, Justin turned into a shark.
Horrified, Christian immediately swam away, afraid of being eaten by his old
mate.
Time went on (as it invariably does...) and Justin found himself becoming bored and lonely as a shark. All his old mates simply swam away whenever he
came close to them. Justin didn't realise that his new menacing appearance would be the cause of such a sad plight. While out swimming alone one day he sees the mysterious cod again and can't believe his luck.
Justin figured that the fish could change him back into a prawn. He begs the cod to change him back so, lo and behold, he is turned back into a
prawn. With tears of joy in his tiny little eyes, Justin swam back to his friends and bought them all a cocktail. (The punch line does not involve a
prawn cocktail - it's much worse). Looking around the gathering at the reef, he searched for his old pal. "Where's Christian?" he asked. "He's at
home, distraught that his best friend changed sides to the enemy and became a shark", came the reply.
Eager to put things right again and end the mutual pain and torture, he set off to Christian's house. As he opened the coral gate the memories came
flooding back. He banged on the door and shouted, "It's me, Justin, your old friend, come out and see me again."
"Christian replied "No way man, you'll eat me. You're a shark, the enemy and I'll not be tricked."
"Justin cried back "No, I'm not. That was the old me. I've changed."......................
"I've found Cod. I'm a prawn again, Christian"
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
