My opinion. This is going to be a top GP. Will be between raikkonen and schuey and maybe a Williams right up there. Webber will get past the 2 Toyotas but will need one of the top 8 to drop out to score some points. Coulthard needs to give up, maybe try for a drive in the V8 supercars or something. Barrichelo doesnt deserve to be at Ferrari either. It might rain, its an early start (10:30pm) and the top 6 is separated by .4 of a second. SWeet.
Or
Schumacher will just walk away with it.
https://www.sau.com.au/forums/topic/19390-european-grand-prix/
Yeah I reckon DC's time is up with Mclarens and RB's time is up with Ferrari. Kimi's the no 1 driver even though it's not public. Rubens didn't get signed up even though the main Ferrari principles did (ie Schuey, Brawn etc...) If I we're manager at Ferrari I'd be getting a young gun to learn from schuey.
NOOOOOOO!!!!!!! JP is a ****en idiot. How is it everytime he attempts to overtake someone theres always an accident of some sort. Any MS just said it was a racing incident. But JP pisses me off. Way too much Indy still left in him.
Sucked in DC, he should retire.
Duncan, JPM overtook MS on the outside while they were going around a tight corner....JPM kept the racing line but still left MS enough room (ie didn't cut him off)....they touched and MS ended up in the kitty litter. Which was unusual they said, cos normally the guy on the outside would be the one to spin off.
even the commentaters said there was no way it was JPM's fault...in fact one said that if they find JPM at fault, he'll personally pay the fine himself haha :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
