just rewmoved my bleed valve and need to go back to stock boost so i can drive the car... i have one hose coming from what is a pipe underneath my intercooler piping on the left side of the engine (facing the car's front end)... one from the intercooler piping itself and on form the turbo's actuator (i think that what the gold drum thingy is)
and i have the stock boost solenoid which has two connectors and electrical wires coming from it.. so where does each tube go.. dont want no overboostin lol
cheers...yup that helps lots. Is useful i think for others too who might not know what it is ;)
Are those wires blue w/ white stripe and white? I have an orphan plug sitting around, just wondering whether its the same one. Does it require power or is it fully neumatic?
hmmm.. well i have the solenoid in place.. From those photos it appears the bottom hose from the solenoid is going to the wastegate, where as the top hose is to the throttle intake? So all should be fine right?
Unfortunately its not, when i connected it like that infinite boost..it just kept going up and up until about 12psi till i backed it off ;)
There is also a blocked outlet on my (stock) BOV return pipe where it goes back to the turbo, so maybe the top hose is meant to go there? Although the pressure should be pretty much the same shoudlnt' it and make little difference?
I mean i can "cheat" and just connect the intake direct to the wastegate and it will hold correct boost (which i'm doing for running around) but its for an EPA so the solenoid needs to be connected (i think?)
Anybody ?? Quicksmart? if anybody has a standard boost solenoid can they jump out to their car and have a close look plz?
Hi,
The bottom line on the solenoid goes to the T piece that in turn goes to the wastegate actuator (where your bleed valve probably is).
The top line on the solenoid goes back off into the BOV return line. As I recall, it's under the air piping that leads into the turbo inlet.
The striped wire (to the right of the plug) is a constand 13.5 volts
The solid colour wire (the left of the plug) is a negative trigger controlled by the ECU to open the solenoid.
The solenoid is fully electric.
line goes from high pressure side of the intercooler to the waste gate, then a "t" piece, the "T" peice runs a hose the the boost control solenoid, then from there to the hose that runs from the standard BOV to the low pressure side, (between turbo and AFM).
ok.. well i got it all sorted the other night..the key is the t-piece between the intake side and the wastegate - the stock solenoid hangs off that, and its different to my EBC configuration where it sits in between. Now rises to a solid 7psi
In the aid of providing a useful resource, i've posted a couple of pix of how I installed it
All was inspected and passed by the EPA correctly :D
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
