bought a set of ohlins adjustable height coil overs that i was told were for my r33. fronts fitted fine, backs did not so i emailed ohlins suspension and it turns out they are suited to an r32.
shocks are adjustable bump and rebound and anyone that knows the quality and price of ohlins gear will know what im talking about when i say these are the ducks guts of suspension.
i am wanting to keep the fronts but will sell the rears.
think they are around 5-6 years old but are in good condition, they use a sirclip to adjust height.
after somewhere around $300 for em.
cheers guys
brett
https://www.sau.com.au/forums/topic/194491-ohlins-adjustable-hight-coil-overs/
What does the bottom mount look like?
Any pics.
And do they come with springs?
If they fit an r32 gtst consider them sold!!!!!
I can pickup on weekend.
Edited by _x_FiReStOrM_x_
pm sent rad33. they definetly fit an r32 gtst. i emailed ohlins in sweeden and gave them part numbers. the front ones fitted my 33 but backs were too short. bottoms of em just have the bolt hole that goes through the bottom of your standard shock so can be changed over in bout 45 mins! they also have a screw and nut at bottom of shock that adjusts the rebound level (i think). i can organise to send some pics through tomorrow night if need be!
brett
and yeah they come with springs, just need the rubber outta the top of your standard ones put into these and will be ready to roll.
