Under the tarmac rally rules I must run 16 inch wheels on the R32 GTR.
So despite doing all my research and then ordering what I believe to be the best value 6 pot callipers And two full sets of pads at a cost of $3k plus air freight plus GST and duty of $550, I now have a set of 6 pots that are brand new, that retail for $5k, that cost $3610.00 that are of no use to me.
They are not a cheap chinese alloy copy but a perfect forged steel replica of the AP racing brake system and they do fit 325 to 375 mm rotors under 17 inch and larger rims.
These are not sold in OZ and are bright red. The company that manufactures them builds OEM callipers for many US, Jap and Euro cars.
I was going to use them on my 260 kilowatt rally car, but now I cant.
Includes adaptors for R33 R34 and Braided lines.
Im in Sydney and I can provide you with a tax invoice on any item.
[email protected]. or 0414 626 243 SMS and Ill ring back
Item: 6 pot brake callipers as above
Age: New
Condition: New
Price: $1,500
To Fit: any car at all but comes with adaptors for R34 and R33
Contact: Dom [email protected]. or 0414 626 243 SMS and Ill ring back
Item: Volks 17 X 10 pro with caps and 265/40/17 tyres, again selling as I must run 16s on the GTR
Age: 2 years
Condition: wheels 9/10 tyres 5/10
Price: $1200
To Fit: (What car) They have the GTR offset so should fit all 5 bolt skylines etc
Item:Nismo struts and king springs
Age: about 3-5 years old
Condition: were perfect on my car but made it too low for tarmac rally use
Price: $100
To Fit: (What car) R32 GTR
Edited by Dominic
  • 3 weeks later...
Age: New
Condition: New
Price: $1,500
Age: 2 years
Price: $1200
Price: $100
Age: New
Condition: New
Price: $1,500
Age: 2 years
Price: $1200
Price: $100
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
