more parts added and thread updated
Brake booster & brake pedal/bracket $80
Clutch pedal/bracket & master/slave cylinders including all lines $100 sold
Accelerator pedal & throttle cable $50
Edited by PT
  • Replies 116
front hubs are still onthe car/available, rear hubs have been sold, no calipers/rotors/backing plates or hand brake cable I am using these
Nismo suspension iss already sold/on hold
is the mtor avaliable. need one to replace the 25 that let go in my 32
if so how much?
oops forgot to add that, yes motor available:
motor/ecu/loom/afm/clutch fan $2500
