its just runnin around weekly on 14 psi n dats plenty of power (288rwkw). i reckon its limit will be 20 psi but not for a daily drive. 18 psi is only if i drag a really fast car on da streets which i've never had to.
Edited by R34JET
https://www.sau.com.au/forums/topic/194872-sold/#findComment-3525307
That's probably 1 of the sickest 34 i seen in a while mate. gl wit the sale. just a query tho.. have you ever been to the strip?? got an 1/4 mile times???
cheers
https://www.sau.com.au/forums/topic/194872-sold/#findComment-3554775
  • 4 weeks later...
wow nice niCE NICE!!!!!! I was initially planning on the bomex whole kit however ended up with the do-luck front, but the bomex does suite nice~ also not only that ur r34 must be one of the fastest GTT too... :P
HEY JUST A QUESTION, would you mind selling me ur power FC by any slight chanCE :P ?
https://www.sau.com.au/forums/topic/194872-sold/#findComment-3604660
Yeh make me an offer.
https://www.sau.com.au/forums/topic/194872-sold/#findComment-3604666
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
