Hi
I have a really good friend that just picked up an R31 GTS coupe, it has the RB20 nics motor in it. The thing i want to know is will i just need a normal RB20 5 speed and then the pedal set and clutch master cylinder out of a aus spec R31? Or do i need the pedal set and master cylinder out of the import R31 coupe?
Also tailshaft? Are the coupe tailshafts different to the sedan ones?
Any help would be much appreciated
Thanks guys
https://www.sau.com.au/forums/topic/194896-manual-conversion-on-r31-coupe/
So it looks like
parts that fit are
-Aus spec R31 clutch
-Aus spec R31 flywheel
-Aus spec R31 g box
-Aus spec R31 master and slave cylinder
-Aus spec R31 clutch pedal
i will need to get a manual import tailshaft or get one made up as the aussie one will devinately not fit.
Ive just answered my own post so feel free to delete it now that i know R31 club exsists :laughing-smiley-014:
Edited by nigelp
Sedan and Coupe tailshafts are different lengths. Deal with as above
Everything from R31 will fit an R31GTS
I believe you can also retain your original pedal box. It has provision for the two manual pedals, provided you remove the auto brake pedal first.
Make sure you use a manual ECU and not the Auto. Auto will work but it'll drive like a pig every time you put the clutch in
Dont forget to join the neutral start relay wires (purple) near the battery
On another note, whilst youve got the master & slave cylinders out put a seal kit through them. Takes 5$ and 5mins each and can save you heaps of time later down the track
Edited by Jmaac
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
