eh?
why would you go else where....
autobarn sell davis craig...and repco sell recpo which is just the davis craig repackaged.
both are fine you just need to get a controller and sensor...i would recommend pivot.
you want cheap - go to any good auto elec and ask for 'oex' brand, good and cheap, davies craig is mid range and spal are top end.
where you located? OEX make EXCELLENT thermo switches which are cheap too, you after electronic switching or mechanical?
im using ICE thermos hehe... works well and use std R32 sensor/switch on rad
u guys do it all the hard way..
K.I.S.S
ICE thermos are made by OEX :wave: there the ones I was talking about hehe good value for money
thanks for the replies guys.
repco wanted to charge me $240 for a 16" straight blade.
supercheap had calibre 16" straight blade for $100
im on the southside so where is a good place to get these oex or ice thermos from? im looking to switch it electronically.
basically my clutch fan is stuffed and im looking at $140 upwards to replace it so was hoping to fit a 16" thermo in the stock shroud for around that price. less if i can.
ive searched and apparently the s shape blades are better which is why i stayed away from the straight ones i dont want to have issues with heat.
thanks alot
thanks alot
repco sell the ICE ones but put a horrible markup on it, kinda complicated to explain the ICE/Repco relationship though. PM me with your suburb and i'll tell you where to go :D
ICE thermos are made by OEX :) there the ones I was talking about hehe good value for money
yep.. :)
thanks alot
hmm $140. ill supply and fit a GTST hub fan for $60 interested.. :3some:
thermos are for E-W mounted engines.. and RB silvias :D
definatly could be interested. i just want to get rid of the f**king annoying whirring noise that im pretty sure the clutch fan is making.
i thought it might of been beneficial to go a thermo fan because it lessens the drag on the engine (yeah i know it probably makes bugger all difference.)
been reading mixed reports about going to thermos though.
I just installed a Twin thermo setup in a shroud. A bit of trimming and it's a perfect fit on a stock R33 radiator. A bit more trimming for a close fit Ally 50mm radiator. Came from a late falcoon for $200 from Autobarn (or less on trade). Used an in hose fitting for the 90deg on/80deg off thermal switch.
I just have to get the current draw right. It's pulling more than 30 Amps so fitting a new relay and stepping up to a higher fuse rating tomorrow.
I am looking at setting up twin thermo's from an AU in my R33 too, how have they gone in yours so far? have you got any pics of your handy work? was the thermal switch expensive?
K.I.S.S
the over temp switch in the r32 rad come on tooo late (90.c) but if u buy a temp switch of a mitubishi lancer/marage /magna (tridon part no TFS141 for around $30 which is a bolt in replacement and it comes on around 83.c
i use these all the time when i do rb conversions into silvias with 1x14in and 1x12in thermo fans on a r32 rad and never had any over heatin issues
well pm me mate.
may do cheaper.. lol
not much diff in going thermo. ull find it will prob over heat. and ull find that ur batt alternator has more load now. so ur car will load up more to charge. yay
cool thanks man, probably send a pm your way in the next couple of days.
as long as that annoying sound is gone at the end of it i'll be a happy camper
cheers
ohh cheers for that mate. ill keep that in mind. havent had an issue with the RB sil yet. its actually been more reliable than my older cars. ill look into switchin it next time i do one.
yeah, clutch fans are way more efficient at cooling the engine... get marki to check it out he's awsome at wat he does
thanks brenton.
hey u wanna come watch at the strip on wednesday night ill send ya a SMS.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
