  • Replies 232
i remember i got 35% tint done and then a few days later had to go through regency unexpectedly and they pinned me for my tint because they said my factory glass had a slight tint or something and i was 5% over the limit and had to get it removed.
this silver skyline was my mates this tint was done @ auto perfection
Paul, he will give discounts for people that miss the group buy, mention SAU or i guess have to go get it taken off for regency and want it put back later
Has anyone paid yet? I can put the $$ in whenever but dont want it too all fall through if we dont get enough people going in. When is it likely to get done, the sun is a bit hot with a black car!
Well I hope other people have paid.
Steve, can you update the first post as confirmation of recieved payment (obv. when you recieve our payments :w00t: ).
I just spoke with the guy from Autoperfection about this group buy.
He said that legally in SA the rear & rear quarter windows can have a luminous transmittance of not less than 35% & the front door windows must have a luminous transmittance of at least 70%. The group buy does NOT including any tinting on the front windscreen. The owner can stipulate on the day if they would like 35% for all windows (not including the front windscreen).
The sticker is a chrome one approximately 25cm long x 5 cm high and looks "classy".
Thanks David that was one point i think i forgot to add about the sticker
Riccardo said wear the sticker as long as you can out of respect i would suggest 1 month minimum
first post updated thanks for payment guys
ok we've had one person pull out this makes 19 people so far and Heslo's Dad whos only getting a half tint front windows only
haha i think thats luke (flicks bf) old dailey, man that thing has some scuffing issues haha
steve, ill deposit the monies when i get paied either this week or next, damn christmas presents.......
That's fair enough, I mean the guy's giving us $100 off the price so I'll wear the sticker for a couple of months no problem.
not to be anal buts its $110 :(, 10 bux is better off in my pocket
when i buy Kyes greedy auto timer i will get Riccardo to install it
Kye how's today or tomorrow sound ;):)
I've called them up and enquired about tint for dad's work car - a Toyota Tarago and for it to be done on a Sunday... waiting for them to call me back...
Edited by vietorious
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
