**UPDATE**
all monies have been paid to Auto Perfection you can now ring up and book your cars in he would like to book 3 of us in @ a time he has the list of names and rego numbers to mark you off the list and so he knows who's paid and what not
those that haven't paid you have 8 weeks to book your car as off the 7th January 2008
Kye - i asked about glue and cause i dont know how much glue there is on how many windows he couldn't tell me how much, you will also have to give me his details so i can let Ricardo know
those on the list that havnt paid that have 8 week are
Auto Perfection
Ricardo 83426644
18. HOSTILE - NOT PAID
18. bunny33 - NOT PAID
20. WLD MAN - NOT PAID
21. kalel's mum - NOT PAID
22. Heslo's Dad - NOT PAID
23. kalel - NOT PAID
23. mrgtt - Just the Misses' car :yes: - NOT PAID
24. Da_Black_Wolf - NOT PAID
25. Furiuz - NOT PAID
26. Top_End - NOT PAID
27. SXY_33 - NOT PAID
28. John - NOT PAID
  • Replies 232
i didnt ask but im guessing it will be as you guys are just like other customers but getting a group buy price
Steve,
Is this a cash only job or will they except payment via card?
Cheers
Howdy Steve,
Is it too late to include me in your list? I'm pretty much on the road full time lately and it's hotter than hell in the car on some days. :cheers:
Had hoped that a bit of tint might provide some welcome relief. :rofl:
Let me know what needs to happen from here. Do you need the payment to go through you still or do those of us left have to make the payment direct to Auto Perfection?
If you want the payment, could you please PM me the details. Did you say you worked in Beverley? I just live down the road in Flinders Park, could probably drop the money off to you if prefered.
Cheers, Mike
no Probs Andrew and if i haven't replied to anyone's emails about thanks your all welcome
please please when you pick up your car after its been tinted remember to thank Ricardo very much for the group buy
and also remember trader rating's, leave a rating get a rating
Oh 3 things
1) no one gets receipt's, i have one bulk invoice
2) dont forget to tell Ric if you want 70% on the front
3) dont forget to tell Ric if you need old tint removed $88 for tint removal
has anyone got a steam cleaner i can borrow to remove the tint on my front window?
Have fun with that! The best method I have found (after peeling off the old tint) is to use degreaser and a razor blade to remove the glue.
Should also mention that they are only
Monday - Friday, 9am-5pm
I'm booked in for thursday next week. :D
Hoepfully I see some of you there.
Regarding, removing cleaning windows, I prefer metho. It will remove the glue but won't leave a residue to clean up afterwards.
Edited by L3nny
Thanks for the shots Steve. I'm assuming that you went for 35% all around? How dark are the driver's & passenger windows at night. I had trouble with dark tint on these windows on previous cars at night, especially if there are no street lights.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
