I slapped my KKR480 turbo on a while back and ever since its been blowing oil smoke... :'(
Obviously leaking down the shaft because sleve bearing sucks.
It wasn't really blowing much smoke then yesterday I put some new oil in it, basicly just to flash it out, some crappy oil thats like $18 for 4L. I was planning to run this for a few 100km then put some decent stuff in it. Any way now the car is undrivable due to the ammount of smoke it bellows.
Before I go an buy my decent oil what do you guys thing I should get, I know that the type of oil does make a difference and the oil seals in my turbo fine its just that its a crappy sleve bearing and rather than having an oil seal it basicly just has a metal C clip and sits on the shaft and oil leaks through it easy as.
My oil drain is nice and big and free flowing but yeah I basicly want this thing to be drive able so I can save up for a couple of months and get a Garret GT40R. So any Idea's on oil, I heard that it will blow heaps of smoke on synthetic because its such a thin oil but yeah what do you think? any Ideas? I am tempted to hit my oil line with a hammer and let the turbo have a slow death from not much oil, atleast I will get my 3 months life out of it... maybe... so I can get a Garret GT40. Nice waste of $950 I guess.
https://www.sau.com.au/forums/topic/195029-sleve-bearing-turbo-setups/
because of the journal bearing you need to feed more oil to it (which is why you need to make the oil feed line bigger to these types of turbos).
look out for a blocked oil drain pipe, blocked PCV, blocked breathers etc.
is there any oil in your cooler pipes? catch can? intake?
perhaps this hasn't been done, and the turbo has now shit itself because of insufficient oil.
there's nothing wrong with a sleeve bearing turbo, if you treat it right. My R31 turbo stood up to 14psi and no BOV for 3 years, plus whatever the previous owner threw at it.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
