R32 what? RB20DE, RB20DET, RB25DE, RB26DETT ?
they are all different is size, but all top feed, so no R33 will not fit unless its an RB26DETT engine you have.
you can not change size unless you reprogram the ecu either, so you must get the correct ones for the vehicle you have.
my advise is get a good s/hand set and get them ultrasonically cleaned if they need replacing for whatever reason.
https://www.sau.com.au/forums/topic/195202-question/#findComment-3497913
hmmm thanks guys i mite go for the gtr ones ?
how much power can they handle ?
thanks
What motor do you have?
If you don't have the correct size injectors then you need a Power FC or the like - otherwise the engine will run very rich, it will look like you have a blown turbo
https://www.sau.com.au/forums/topic/195202-question/#findComment-3499072
GTR injectors can handle high 200rwkw and maybe even 300rwkw.
You would need a resistor pack of some sort and a retune of the standard/aftermarket ecu to control the new injectors. You won't be able to do it on the safc as far as I know.
How much power are you making at the moment? And how much are you planning on making? You can keep the standard injector and make 200+rwkw with a good tune. Just make sure they're in good condition and are clean.
https://www.sau.com.au/forums/topic/195202-question/#findComment-3499230
You can buy a genuine one for ~$120 or make one up yourself. If you want one made up, just go to jaycar or dick smith and buy some resistors and make them some how I can't remember. Try a search on the forums and you'll find all the information you're after. I think it was Roy who also made a tutorial on how to connect up the resistor pack.
https://www.sau.com.au/forums/topic/195202-question/#findComment-3500467
The standard rb20 injectors are high impedance and the gtr's injectors are low impedance. What the resistor packs do is it increases the resistance for the standard rb20 ecu to be able to control the gtr injectors. It's something along the lines of that, not 100% sure though. You just need it if you've got the standard rb20 ecu and plan on running any low impendance injectors.
https://www.sau.com.au/forums/topic/195202-question/#findComment-3508131
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
