  • 1 month later...
people have always asked for an external gear changer with the proper slots instead of just up and down, and also a clutch.
i read that polyphony/sony were not interested in doing the whole 'proper gear setup' coz "each car in GT is different and you wouldn't be able to feel the difference.." EG some cars have 4 gears, some 6. it would be wierd.
BUT WHO CARES HEY?! i'm dying for a proper setup. to the point where i might have to try make one on my own or employ someone to or something. i'm sure the demand will be there because with GT5 being physically and graphically very life-like, a proper stearing mechanism should be on the cars (EDIT: i meant on the cards, not cars; but it workd both ways). I can only hope that they are developing one in secret and then... BAM, release it and stun people.
That's what I hope anyway
Edited by ALEX!
easy fixed...
Get a G25.
yeah get a g25, they are fairly cheep at dick smiths, got mine for under 300. been playing gtr 2 on it for weeks. tho to tell you the truth the h pattern shifter gets a bit too much and i use the paddles most of the time.
but all in all they are a great wheel
  • 3 weeks later...
thats some nice work man, :D unfortunately all my spare cash is going to be going on investing now but ill deff have to whip up something like that in the future.
that lil chair in yours looks like it could get uncomfortable after a while though :/ but nice all the same
thats some nice work man, :( unfortunately all my spare cash is going to be going on investing now but ill deff have to whip up something like that in the future.
that lil chair in yours looks like it could get uncomfortable after a while though :blush: but nice all the same
:nyaanyaa: It didn't actually cost that much to put together. The timber I found on a building site, small pieces of mdf was what I had left over from building my poker table (that's another story) and the chair was only about 30 bucks from Ikea. Just took a hacksaw to the legs :P
And it's surprisingly comfortable. Been doing some enduros lately and no complaints.
My mate has one he made of steel for his Forza wheel and utilises a VR commodore seat including the rails so you can adjust it for his tallness or my shortness.
He WILL be building one for me to use with my G25 on the PS3 :blush:
I'll try to remember to get some pics next time I'm round there.
  • 3 weeks later...
He WILL be building one for me to use with my G25 on the PS3 :cool:
Does the G25 work with the PS3?
Even the wireless functions?
  • 1 month later...
Im impressed bigslick. I want to build something like that but for the xbox wheel. How did you decide on the dimensions of everything?
Just took a few measurements while I was in the seated position I wanted, drew a few diagrams (yr8 tech studies came in handy for something) and did a few calcultions. Just in case it helps you to get started, the dimensions of mine are: length 1305mm, main frame width 575mm, main swingarm length 655mm, seat height from floor 250mm.
Mine is nothing special by any means. It does show you can easily buy basic stuff and have an OK setup.
G25
PS3 (GT5)
PC (GTR2)
(Note: the gear shift holder for my driving frame since arrived and has been connected, hence why the gearbox is "seperate" in this picture)
Edited by TommO
  • 2 months later...
  • 11 months later...
OK. So it's been......... WOW Almost a year!! :D Oh well, time flies.
Anyway, finally got around to upgrading the Playstation cockpit.
Bought a G25 (40% off at Harvey Norman) and car seat from Supercheap and knocked up some plans.
Me cutting out the side panels
The seat on it's custom base is detachable so it can be used as a normal lounge chair
View showing the gearshift mount box. And the flash showing up my blotchy paintwork! :)
Took the measurements from seating position in the GT-R.
Waaaaaay more comfortable and the G25 feels awesome ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
