I would say the gains would be minimal. But good enough.
The catback itself would have given the biggest gain.
In my experience, i started with the HKS Catback, then put on a de-cat pipe and there was squat all difference.
Basically you wont fell any noticable gain.
cheers mate
You listen to a Kiwi? :rofl:
jks, Family is from there, and lived in NZ for a bit.
I'll give you my theory:
You have a hose, Water is flowing from the tap/turbo, exits out the exhuast/end of hose.
You remove finger from the end, flow increases, pressure drops. You remove a bend/kink that is increasing pressue and hampering flow(think cat), resulting in gains. You free up the small fitting(dump pipe) and a heap more water again can flow, and having the larger piping the whole way through allows it out.
On RB's the dump holds them back, compliance cats are tiny(have a look). A cat doesnt flow anywhere near as much as the straight pipes(look up figures), so the more it can flow the better for the whole system. If you didnt notice at this stage from changing, either your cat wasn't overly restrictive(don't know about NZ compliance), or you aren't at a stage where you can notice it.
I personally would do it sooner rather than later, best off to maximise what ever you have, before trying to do more when the weaker links havent been brought up to scratch.
Hope my tired ramblings helped.
-Ryan
You listen to a Kiwi? ;)
-Ryan
Thats not very nice :) haha.
I guess i didnt notice a difference when i put in my de-cat ( yay for not having emission laws.. yet ) because my Skyline had only done 49,000km, ( now 50,000 :rofl: ) so it was probly not overly clogged up.
The biggest change i noticed was it gurgled more at idle and the note when driving was a little more pronounced.
Oh, and it spat a few flames when the exhaust was very hot, after long drives etc. After a squirt of boost and gear changes.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
