hey everyone, skyline bodykit 4 sale, need to offload asap!
1 x 400R frontbar (unpainted)
1 x set of nizmo sideskirts (unpainted)
the bar and skirts owe me just over $1k,
never been fitted or painted,..
open to offers, lemme know..
Mobile : 0405 650 930
asking $650 for the lot ...
https://www.sau.com.au/forums/topic/19588-r33-bodykit-brand-new/
  • Replies 44
Sounds nice but your about 3mths too early for me.
I just ordered a 400R sideskirts and a 400R rear bar last weekend and now im struggling to get funds for the painting/fitting.
A 400R would go nicely (although verrrrry low).
can i also get pictures, interested in purchasing complete package - also is it for a series 1 or 2?
pm or email me please on: [email protected]
cheers
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
