Hi all,
Got a Greddy Plenum, Forgot About A throttle body but ill just get an 80mm and weld it on or a q45.
What i need is the piping to go from the the plenum to cooler or is there a piping kit greddy make or someone else makes that will work?
If greddy makes one can you list where and model no. if avaliable
Cheers All
Peter
Edited by INFRNT
there is no actual piping kits that are made to suit the front facing plenum. most people just get the pipe custom fabricated. and if i were you i would use the q45 throttle body over the 80mm. no need to weld anything, and they make an adaptor plate if it doesnt fit.
