hI GUYS, my uncle and I have recently fitted an Apexi AVC-R to my r32 gts-t. In the etc. menu I have put the correct settings to what car it is etc...
Although my problem is that its boosting more than it should. I have set it to 0.7 bar (11psi) and through testing its reached a max of 0.83 bar and an average of 0.76 bar.
I believe that the duty cycle may need to be set properly. I know that the AVC-R is wired correctly because its showing correct stats on speed, revs, boost etc...
Maybe I have left something out although I can only think its the duty cycle at this point in time.
Thanks
Mark
https://www.sau.com.au/forums/topic/19609-avc-r-help-please/
  • 3 weeks later...
Try turning the AVCR off, and taking the car for a drive under load. When i do this my AVCR recalls a boost of 0.83-0.87 bar.
As such it is impossible to drop the boost level to below the actuator boost level.
I have Setting A set up to run 0.85 bar but ramps onto boost a little quicker by reducing wastegate creep. It holds stable boost pressure and never goes over 0.90bar
Setting B i have set on 1.0bar but have only used it about 6 times, as my car pings a little, and unless running toluene doesnt really add any performance.
With a 25% mix of toluene the old girl has plenty more top end.
https://www.sau.com.au/forums/topic/19609-avc-r-help-please/#findComment-443741
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
