Hey guys i want to send my used 19" rims with tyres to Melb, any good Freight companies recommend? cheers
Pack and send..
http://www.packsend.com.au/
I also use TNT for work and they are pretty decent.
http://www.tnt.com/country/en_au.html
https://www.sau.com.au/forums/topic/196201-freight-company/#findComment-3511926
Couriers Wordwide Express
http://www.cwe.com.au/
These guys are a courier broker.. They use mainly TNT couriers end to end, but you only pay a fraction of the cost of going to TNT directly. For example, I sent a 42" plasma TV. Box was over a metre long and 80cm high weighing 50kg. Cost me $55 to ship from Melbourne to Sydney. Unbeatable price! A TNT courier picked up the box, and a TNT courier dropped it off too.
https://www.sau.com.au/forums/topic/196201-freight-company/#findComment-3511945
thank guys,, on more question. .i'm gonna send the 19" Rays with tyres out should get a BIG box for each wheels or just hand it to courier company? cheers
A courier company wont take them unless they are boxed up.. Maybe visit packsend to see if they've got boxes big enough to fit all four tyres/wheels. Most likely though you'll have to pack them separately. Call your courier company and ask them to quote the price for one big box (you will need dimensions + approx weight of the box), and also get a quote four smaller boxes. They SHOULD work out about the same, but sometimes the price changes over a certain size/weight because they need to send a truck with two guys or a hydraulic rear loader (because one guy in a van cant take a giant 80kg box cos he cant lift the box on his own for example).
Keep in mind that the smaller your box is, the cheaper it will be. So try to find boxes that perfectly match the size of the rim+tyre. If they dont, modify the boxes so there isnt too much wasted space.
https://www.sau.com.au/forums/topic/196201-freight-company/#findComment-3511994
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
