Hi guys, and girls
My name is sen, im from melbourne. i got a R34 GTT , i wana rebuild the engine.since im gona rebuild it ,im wondering what can i do to put more power at the wheels,I even think rather than rebuilding with pistons, can i buy a R34 GTR second hand engine. is that possible?im realy confused with everything, and anyone know roughly how much to get it done?
looking forward to hear from you .
once again its nice to see all you skylines togethr.
thank you
Sen
Edited by sen
https://www.sau.com.au/forums/topic/196246-hi-guysim-new-in-here/
thats a very vague question, all depends how much power you want, and how much money you have to spend.
Wats the compression readings on your current motor? what mods do you have right now?
The engine itself wont be the limiting factor if your running the stock turbo, you could rebuild your engine to factory spec but with the stock turbo your not going to get much over 270rwhp.
The price of a rb26 would out weigh the cost of rebuilding your current engine (depending whats wrong with it), and you would still be stuck with a second hand engine if you went the rb26 route. Theres heaps of info on here about the pros and cons of pretty much an setup you could think of, so have a search around and get a general understanding of whats possible.
You could rebuild yours to factory spec, or build it tough with forged internals
you could get an rb26 engine or you could stick a rb30 bottom end and get even more displacement (theres a whole thread on that one)
Before you go crazy with rebuilds, if you want more power, you'll need the basics, like FMIC, full exhaust, boost controller, better clutch etc all depends on what power your chasing
anyway welcome to SAU
Edited by R34GTFOUR
Thankx R34GTfour,
my mods are
HKS INtercooler
HKS MUshroom podfilter
HKS pro ecu(not tuned yet)
Apexi Full exaust
Apexi suspesions
Blitz electronic Boostcontroler
and thats prty much it.
im running on stock clutch at the moment.
im gona start savin money now. im thinking of spending arnd $6000 or more if i thik its worhtd.
I will be happy with 250rwkw..... and i dunno how much im running on now... any idea?
is gtr engine gona fit that budgt?
i have just replaced my motor on my r33 with a second hand one and stock its puting out enough power atm for me to be satisfied with it for a while....rb26 will send you back a bit more then wat a second hand motor would cost ya....but in saying that you can chase some big power with a 26 setup....another option is to rebuild your current motor with forgies and bigger turbo setup....also do the cams and stuff like that and you will be pulling out huge power....downside is its gonna hit your pocket hard
GTR motor plus gear box around the $6.5-7K mark.....and then you have the dilemma of getting it put in....
Edited by Krishy
thanks krishy,
yee the money is another problem.if i rebiuld with forged pistons,is dat gona giv me more power when im running on stock turbo, cuz i cant run on hi boost since the turbo is stock.how mcuh it will cost to put in the engine arnd 2k?
well it sent my back $5K for everything that i got done....and that was getting a motor $1880....labor to get the damn thing in $1500...and the rest was spent on parts and other labor hours....i got all the fluids, water pump, timming belt, most sensors, new engine mounts.....and a lot more....it was worth doing it as well i reackon as my next service is a long while away....
a rebuild of my old motor was going to send me back from $6-8K....and that was rebuild with everything forged and all that...
on a stock turbo you can safely run 12 psi mate....no problems....if i were you then i would take the easy way out and buy a second hand motor and slap it in....run it on stock boost for a while...then with the mods you have get it all tuned out and safely boost it to 10-12 psi....
Thankx R34GTfour,
my mods are
HKS INtercooler
Apexi Full exaust
Apexi suspesions
If your only chasing 250rwkws than 6k should fit in that budget, but it also depends on what damage has happened to your current engine.
The neo rb25 (the engine you have), is a bloody strong engine which can handle alot of abuse. Im not too sure why yours decided to die, but if its low on compression lets say worse case senario you melted a piston or your rings stop sealing.
So just a basic rebuild and freshen up, ie new bearing, new rings, all new seals, new pisons (if 250rwkw is all your chasing stick with new stock pistons), and keep everything else like your rods, cams etc then i would expect a bill of around 2500-3000.
Aa new clutch for 800-1000 to handle the power
A new turbo (gt2871R should get that power and be ultra responsive on will be a bolt on but wont leave you much head room for more power, or go a gt30r to chase bigger numbers which would be around 1700-1800
A fuel pump wouldnt be a bad idea
You have most of the bolt on stuff, but you'll need a good tune which is more $$$
So you can see it'll add up very quickly but if you shop around and get some knowledge of what the parts are worth your budget should be intact, but this is assuming you are willing to do some of the work yourself
Edited by R34GTFOUR
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
