Hey all
Just a quick question. I've recently bought a brand new gt3540 and i noticed the compressor housing looks different to other garrett turbos ive seen before including other gt3540's. All the others had the a/r stamped on the compressor housing and had a rather smooth surface. My turbo compressor housing doesnt really have anything on it and the surface is a lil rougher. I had a look on the garrett website and the picture of my turbo on the website looks the same as mine so i'm not overally worried but i admit i still am a lil as i've never seen another with the change. Has anyone come across this before or know of any change in the casting process?
cheers
https://www.sau.com.au/forums/topic/196578-gt3540/
  • Replies 42
did you buy it from slide performance? i got mine from them and mine was identicle to urs (also a gt3540) so i took it to my tuner and he identified it as an genuine 3540 but with the old comp cover.. i got slide to polish mine up free of charge :(
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3517945
yeah mine is exactly the same as lthlrb. No chance of getting mine polished, Sliding performance have been nothing but a nightmare with my experiences but i know the moderators wouldn't appreciate be bad mouthing their biggest trader so i wont say anymore than that
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3519990
Kemp, who fancy drilled those covers, not Mr Turbo jobbies are they?
Cheers
nah they arnt mr turbo job's
u see the 2nd turbo from the left?? thats mine :D i'll be puting that on my GTR but B4 it goes on the GTR im gonna put it on the 180 and gas it and see if i can crack into the 400rwkw mark with a SR20
the turbo's full custom the compressor housing was machined by ATP over in the states and the exhaust housing is a custom in-house casted exhaust housing
its a T4 flange and its divided aka twin-scroll/spit-pulse A/R .70 <----- thats right its not a typo .70 u guys have any idea how responsive thats going to be and it will also have enuff top end to make over 400kw
the housing can not be bought from garrett because garrett dont even make them
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3520091
LoL, you couldn't resist, like a kid with a new toy at show 'n' tell :D
The SR setup should be wicked, good luck man!
*waits for Disco to come sprinting over, all frothy mouthed and sweaty palmed over the TS setup*
i seriously cant help it aye
my mate made more power then me and i wanna blow him away so im gonna up the turbo and gas the car just to make it in the 400kw mark which has been done with the SR20 B4 but ive neva done it so i may as well
the GTR project will have to wait the 180 is more important to me right now
Edited by STR8E180
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3520143
u see the 2nd turbo from the left?? thats mine ;) i'll be puting that on my GTR but B4 it goes on the GTR im gonna put it on the 180 and gas it and see if i can crack into the 400rwkw mark with a SR20
Just to clarify are you talking PULP?
Or, which i suspect, on non pump?
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3520357
i got mine polished because it was ugly, had a burr mark and crap on it.. got it polished thru slide, as i wont be happy and say "oh na its ok i payed 1700 for a turbo and its not what i like" f**k that. I would have gone to the extent and flown over to see jason myself.. and made him change the cover or polishd it. simple.
ill post a pic of my turbo when i find a pic :)
also the manifold wasnt the best, rob hadto do some fab work to it, cut it and move the turbo away from the head, cut the external wastegate flange off and reweld a new one in from the side just under the flange. so it looks different to how it is when we dummy fitted it.
Edited by LTHLRB
https://www.sau.com.au/forums/topic/196578-gt3540/#findComment-3520917
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
