Item:
apple ipod 30 gb video
xbox 360 premium
Both new
Condition:
Nice
Price:
apple ipod $250 ono
Xbox 360 Premium - $400 ono
Call of Duty 4
Assasin's Creed
Halo 3
Need For Speed Pro Street
The Simpsons
Project Gotham Racing 4
Fifa 08
Tomb Raider Anniversary
Mass effect
The Colden Compass
Kingdom Under Fire Circle of Doom
NSW
Contact:
Skylinesaustralia.com forum and pm
Comments:
Hey there both new just sellin these because i need some extra christmas money
https://www.sau.com.au/forums/topic/196804-hey-selling-xbox-360-n-apple-ipod/
replied to them all! both the xbox and ipod need to go the xbox has all the correct information and original wrapping plastics its just like new! Chuck me a offer and its yours!
yes but i dont have the AA batteries for it people are welcome to come pick it up also just pm me!! please no timewasters!! will sell cheaper if someone is serious also have the driving wheel for car games and a memory card!! all pms replied to :P pm me for pictures
Edited by Macedonia_chick
Pm's all replied to just so everyone knows the games are all original its not chiped or nufin like that.. Most of it is was from harvey norman and yes u can play xbox live with it.. =D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
