Item:
R32 GTR Wheels With Tyres
* Full set in Immaculate Condition - Next to no scratches
* 2 x Wheels have full slick tyres and other 2 have normal street tyres
* Condition of tyres - Slicks have plenty of meat left
- Street tyres are abit worn on inside edge (from memory, will check tonight)
Condition:
Immaculate
Price:
Offers over $1000 (will put definite price up within the next few days)
Comments:
Will post pics within next few days
Item:
R32 GTR Power Steering Fluid Resivour
Condition:
Good, Used, but hasn't been in car for over a year
Price:
$40 ono
Comments:
Pics will be up in next few days
Item:
Straight plug in ECU - Impul Hi Power ECU came out of R32 GTR
- Better air fuel ratios
- Removes speed cut
- Increases rev limit to 9000rpm
- Tweaked fuel maps so you can run more boost safely
- Plugs straight in, no other modifications required
Car made low 2**kw with this computer, exhaust cam gear and catback exhaust. (will look for dyno sheet)
Condition:
Used, Couple light scratches on case (Computer not affected)
Price:
$350 ono
Comments:
Item:
NGK Iridium Spark Plugs - BCPR6EIX-11
Condition:
Brand new
Price:
$85 ono
Comments:
Sydney, St George Area
Can meet up local for pickup
Contact:
Through here, or call 0409 653 450
MORE PARTS AND PICS WILL BE ADDED ONCE I SEE WHAT I HAVE
Thanks
Edited by belo
https://www.sau.com.au/forums/topic/197137-fs-r32-gtr-parts/
interested in the power steering reservoir actually just the lid, are the wires that connect to the lid still in good condition, mine were broken on removal. also chasing the carpet from the boot if you got it?
  • 4 weeks later...
  • 1 month later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
