Hey Abu - I've been alright mate. Let us know how you find it with the stock airbox on without any modifications done to the box.
I guess it might not increase HP with a pod (i guess it also depends on what brand/type as there's some shoddy ones around), but for me it has definately felt more punchier, especially in the higher rpm range for some reason i have noticed.
Interesting none-the-less.
Will post up results when once I get the air box on.
Yeah wouldn't be an increase in HP, just response if anything but would get plenty of heat soak. You can feel the hot air as soon as you open the bonnett from driving so you can imagine that pod filter just sucking it all up when you take off at the lights or from standing still like GTST was saying.
When freeway driving or moving it would be fine as constant air flow would be coming through from outside so you generally get boost pretty quick I reckon.
Will be interesting to see either way.
Even with the air box I get a loud spool, but nothing like with the pod.
I think I will unblock the BOV as well and have it running like stock, all smooth like from factory :D
  • Replies 64
years ago I also posted some results I got with a JAYCAR temp probe using pod, shielded pod and airbox in different conditions like traffic, 60kms/h, 100kms/h etc..
If you feel like searching...
is this your old R32? http://www.pbase.com/the_r32/inbox
I tried having a quick look but I couldn't find it.
Works out anyways so I will have a look when I get home.
Thanks for the info.
Edited by abu
Anyways, I will put the air box back on tonight with a new panel filter so see how that goes.
just make sure you make a CAI for it.
i went down to the local car wash who are pricks and cut a half metre off their thick vacuum cleaner hose!
i pressure cleaned it of course :D
i pressure cleaned it of course :)
LOL thats gold, never thought of that hahaha
Yeah will setup a CAI duct, will look sick in the GTR bar :)
:D
Edited by abu
I'm currently at 268rwkw on 15psi with my stock airbox and umm still running with a stock paper filter. (but with a 100mm cai in to its base).
Next time I'm on the dyno and pushing 300rwkw+ I'll lift the lid off and see if there's any difference.
I doubt it personally primarily due to the 100mm cai i have carved in to the bottom of the box.
Thats a fair effort man, will be keen to see results at the 300rwkw mark with the lid off/on.
Is there much difference with/without the CAI?
Got my stock air box back on, seems pretty punchy and don't seem to get that flat spot I was getting just under 3,000rpm anymore.
Seems to hold about 0.85bar boost very smoothly with NO BC on stock turbo :banana:
Anyways pretty happy with the results, just need to change the foam filter to a paper and I'll be all set :bunny:
Edited by abu
I experimented on my 32 gtr, which runs 14psi @ a cat back xzaust. I bought the car with blitz suflow (mesh type) pods fitted. The previous owner gave me the stock airbox with a k&n. Did a swappsies cause i wanted that factory look aswell as hooking it up to the factory cai/resonator setup. I lost ~1psi of boost pressure, the intake sound disappeared and it was a lot slower getting onto boost. felt very sluggish & revved so much slower up top. Couldnt believe the difference
After finding a thread which was currently on the go comparing hte exact same comparisions (and a ~35kw diff on the dyno) some of the guys were only leaving the top 1/2 of hte box in place. Tried that & siliconed the k&n into place. Results: factory look (unless u look close up), top end power back, good spool rate back and some induction noise back, but not as loud as the pods.
mike
If it's going into the bottom of the box, wouldn't that air then be bypassing the filter?
ay guys,
i was thinkin the other day about snorkels and stuf that directs cold air to the air filter and i was wondering if it made a different with turbo cars.. cauz when the turbo compresses the air dosnt it turn hot anyway??
The R32's use a typical airbox setup. The r33's are upside down which makes it difficult to get a decent cai in to them.
ay guys,
Regardless, the cooler the air the cooler it is going to come out the other end.
The reason the air heats is due to compression + lack of compressor efficiency; the higher the efficiency (look at a few compressor maps and the efficiency islands) the less heat that is introduced in to the air = increased density/oxygen = bigger bang.
Shit.. I forgot all about that site... lol..
thanks man..
Time to move those photos..
yes that was mine..
Makes me want another one now.. :bunny:
had a little ARC SMIC tucked away in that front corner too.
actually.. in this pic
http://www.pbase.com/the_r32/image/22963808
you can see the little Jaycar temp display near the ashtray..
and in this photo
http://www.pbase.com/the_r32/image/22963789
you can see the dodgey white cable running across the firewall down to wards the turbo area, which then heads to the airbox and the probe was screwed in to one of the AFM bolt holes.
So the air temp reading was taken as it entered the afm.
thanks man..
yes that was mine..
lol thats cool.
ARC cooler hey, how did it go and what mods did it have?
and in this photo
Haha you can too! Very nice little setup.
Nice looking car but, silver R32 alll thee wayy, you should get another one!
Whats with your radiator, how comes the outlet is in the centre of the radiator?
Edited by abu
and in this photo
Looks almost identical to my car man, same kit except I got a GTR front bar and mines heaps lower.
Edited by abu
Radiator was an aftermarket item.
well not so much aftermarket..
more from another car.
it was twice a thick and a little wider and a little taller.
ARC intercooler was good.
wasn't really pushed much.
I only had 155rwkw with 11psi
is that with the stock turbo?
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
