Item: WORK Meister S1 3P wheels
Age: Used
Condition: Good
Price: SOLD
To Fit: 5 Stud 114.3, 18x9" +30 offset (stamped 27 on rear of rims)
What car Skyline, Supra etc
Contact: 0411 576601 or [email protected]
Comments: WORK Miester S1's, Charcoal centers with polished 3" lip, 3 piece forged modular construction, super lightweight forged wheels with a 'new' cost of $4k for rims alone. WORK is Japan 's premier manufacturer of high quality automotive performance wheels. These wheels have come off my V-Spec R34 GTR, minor gutter marks (see pictures) Tyres on them are Yokohama 265/35/ZR18, tread is low (see pictures) These S1's are very sought after. Reason for sale, upgrading front brakes to 8 pot which require 20" wheels. The wheels can be viewed on vehicle, they will be available at the end of December when new wheels arrive. A deposit will secure the deal until they are ready for delivery. Freight is at buyers expense. Nuts, locknuts and 4 wheel spacers also included
Edited by GO NUTS
https://www.sau.com.au/forums/topic/197365-work-meister-s1-3piece-wheels/
interested.
can you get a side pic showing the amount of dish?
best price delivered to sa?
please get back to me
Hi there, sorry but they look like they are sold pending payment.
  • 3 weeks later...
