Hi guys,
i found this one one of the discount websites im registered with and thought some of you guys may like in on this deal
me and Bunny33 have gone halves in a set, there are 29 sets left mine is being AAE posted i will post up picks when i get it :(
Details
Our Price : $139.95
Average Retail : $189.00
YOU SAVE : 26%
Features:
* Massive 7 km range
* 1 Watt transmit power
* 40 Licence free channels
* 38 Privacy codes (CTCSS)
* Range extender in duplex mode
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Battery level indicator
* Low battery alert (audible)
* Roger beep
* Channel busy indicator
* Time-out timer
* Call tones
* Accessories: 1 twin desktop charger, 2 rechargeable batteries, 1 AC adaptor, 2 replaceable coloured faceplates
* 2 bonus microphones
Specifications:
* Two-Way Radio Dimensions: (H) 17cm x (W) 6cm x (D) 3cm
* Brand: Motorola
* Model: T5509R
>>Product Link<<
https://www.sau.com.au/forums/topic/197395-walkie-talkies/
Details
Our Price : $139.95
YOU SAVE : 26%
Features:
* Channel scan
* Keypad lock
* Keypad tones
* Backlit display
* Roger beep
* Time-out timer
* Call tones
>>Product Link<<
Hi Steve, I don't want to take anything away from the quality of these units but a 1 watt radio wont give you 7km range in Adelaide you'll need a 5 watt in perfect condictions to come close. We use radios regularly on the road and find that the way they are rated is at night in the country with no buildings or trees around.
Having said that, if you need something for communication between 2 cars driving together, 1 watt is definitley the way to go because it won't chew up battery life and won't get too hot.
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529473
i was going to get a pair of the Uniden ones for $50 but i thought even that was expensive for something i might only use once a month...This looks like a great unit and deal though for sum1 who decent quality...
Maybe we should organize a group buy for some :banana:
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3529507
Steve I want a set tell me whats needed for you to obtain these for me.
if you want put $155 in my account and i will order today will get here on monday if you do ring me and let me know so i can put order in ASAP 0421932750
https://www.sau.com.au/forums/topic/197395-walkie-talkies/#findComment-3530190
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
