anyone do competition..
ive done a few not real big comps in my 33, got a good set of 6 1/2 inch splits in he front, and 6 by 9's on the rear shelf that will soon be traded for some good 6 inch speakers all run by an overly big amp, the imaging is great, i am soon to buy another set of splits for the front doors and make some custom pods and up grade the bass side of things, and a crossover will also be used when i do this. Its entered in a sound off in two weeks but im not expecting to place as its more an sq set up. I am also enterd in an SQ comp in about 4 weeks, ill u all know how i go.
Guest purple_reign
yeah, it has 6 1/2" splits in the front, no rear fill dont need it. 2 15" in the boot.
it has unreal clarity, tonal balance and sound stage etc. but that chick in the image projection track can be rather FAT at times... :lol: (scored well last show, i spent longer tuneing it this time).
got 2/ 1st and 1/ 2nd out of the three SQ comps it has been in so far though.
like to hear about everyone elses system/set-up etc.
I'm currently installing a system I hope will be S.Q. competition standard when finished. I don't know if I'll compete because there don't seem to be any comps near where I live and I don't get the time to travel.
I'd like to hear peoples ideas on how different speaker locations sound in the R32 as I haven't decided what to use for F.S.
im in the process of installing mine so yer im up for competition once its in, im puttin in
2 alpine type r 12'' subs
2 pioneer 760w amps,
1 jaycar 4x100wrms amp,
kenwood 300w 6x9''s,
apline 160w 6'' splits.
so hopefully that will be good to start with but if not i can always progress up the lader and upgrade.
cheers...
Guest purple_reign
if you want save some $$ you dont need rear fill (6x9's) if you are going for sound qaulity competitions. depends how you tune it, but rear fill other than your subs will stuff up your imageing and sound stage points.
make sure you take some pics dude. judges like a detailed intall portfilio, specially showing the things that you cant see..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
