Just saw these two abominations in the pics fromt he casting of f&f2... they're the back ends of eclipses... ewwwww
Worse still there were only 2 or 3 genuine skylines that rocked up... the rest were all hondas n eclipses n even hiyundai elantras... all sporting T wings... makes me wanna rethink putting a T-Wing on...
Yous two need to settle down or i'll bitch slap you both so hard you'll be rubbing your faces till you're old enough to get in the drivers seat ok :sly:
And that is so wrong, those two should be shot. If they put those in the movie i swear I won't go see it on principal.
dude i'm already in the drivers seat.......never said I drive legal though:rolleyes:
Its funny, most guys thing NOS means Nitrous... in fact its a brand of Nitrous. A fair few of the cars they showed in F&F had no turbo's n **** in em and were stock as a rock, but whack a bodykit on and you have a machine with added BOV souund effects. To someone who really appreciates cars, they're obvious.
Anyways... its cool to do in a country that has no skylines (or very few) like america, but it jus seems wierd to us i guess...
I got urls for em... i'll find em again soonish
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
