Need some advice.
last weekend i was driving and i saw my oil light flickering and the engine started to sound like a diesel engine, so i parked the car and let it cool down and then checked the oil and it was full, so i went home and did a change of oil and filter, started her up and the problem looked like it was fixed, so i took her for a drive and i noticed that when the temp. reached 1/2 it started to do the same thing. My feeling is that the oil pump is on its way out, so as the engine gets warm the pump starts to shut down. Anyone every had this problem? Am i thinking along the correct line or is there something else wrong with the engine? Any help would be good
p.s. its a rb20 single cam engine
Thanks
Edited by who's next
https://www.sau.com.au/forums/topic/197585-a31-problems/
to take the sump off u can either pull the engine out or if you have access to a hoist support the engine using a special support bar and chain then drop the crossmember off, i know koz i did this myself on my 32 koz it had the same problem but after cleaning out the sump an removing the oil pickup an replacing the gasket it was fine, it only made it easier for me being a mechanic so i could easily drop the crossmember without takin it right out, by which is a total biatch to get back together
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3535648
I used this opportunity to tell the wife i might need to change my engine and to convert my car to a project car (as i would like to do everything meaning and build up a good strong car), so i went by a guy who brings in used parts from japan, and told him i was interested in going with the rb25det set up. I had my heart set on the neo rb25det, but he told me that engine is trouble and to go with the rb25det with the ignitor. Now i have been searching on the net to see people's experience with both engines, but i have not seen anything bad about the neo. My thinking for going with the neo is that its a newer engine which should = less miles and its rated at 280hp the same as the rb26dett (without the cost of the rb26).
Have any of you guys had a bad experience with the neo?
Which one would you suggest neo or non-neo
thanks.
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3538146
Thanks guys, I would go with the neo, its 3,000.00 more than the non-neo. I think this guy brings in good parts, i have bought parts from him and so far no problems. So my baby would be out for a few months as i plan to do it like a project car (diff, fmic, suspension etc.) every month i would buy something and put on before the engine goes in, that way i would have a good strong/safe car at the end of the build. would take pics and step by step and post it when she's done.
Thanks again
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3540234
this down in Trinidad and Tobago so that's TTD so the non neo would be 12,000.00TTD and the Neo is 15,000.00TTD, now you could get it for less but this guy brings in good engines and i think its better to put the extra to get a good engine, plus if there are any problems he does not give trould to change the parts. yeah things down in trinidad real expensive.
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3553276
i put a rb25det s1 in my cefiro, whole time i planned to run a neo or even 2j but when it comes down to money you can only do so much.. if you stretch your budget too much you'll end up with a dodgy set-up rather than something similar thats very reliable
s1 or s2 ftw !!
https://www.sau.com.au/forums/topic/197585-a31-problems/#findComment-3567715
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
