Looking for some grip/drift suspension alignment settings for a31.
Like distance from wheel center to the guard. Toe, Camber, Caster.
Maybe some suspension components advice ? Swaybars, spring rates.
I have stock suspension arms all around(accept for front S14 lower control arm for more track and camber), non adjustable(accept front camber, front toe, rear toe).
With Energy suspension bushings all around. I got coilovers all around 6/4kg spring rates.
I got pretty thick, but solid swaybars all around.
Car height: From wheel center to wheel guard. Front 330-340mm. Rear - 370mm.
I did alignment today, and I had nearly -3.5 camber on front left and -2.6 on the right side. Had to use coilover top camber plate to adjust camber.
Adjusted to ~-2.5 up front. Toe in was nearly 0 degrees. A bit negative. Don't remember the caster.
Rear camber was around -1.5 degrees, don't remember the toe. But it was a bit negative. Toe in it is ;)
What tires I will use:
Grip: Dunlop 9000. 225/245 17 inch. on 8j/9rim for track work.
But I tend to think some 225 on 16inch 8j gtr rims all around will do better for track.
Drift: Anything I can find in the rear from 205 to 225. Front - 225.
What problems I've encountered so far when drifting:
I have hard time swinging the car effortlessly. I have 1way nismo diff. And in the S-bend. When I lift off the throttle I don't get any smooth transition. when I lift off, car wants to regain grip as soon as possible. Frustrating. I blame my 1 way for it. But who knows, maybe you guys have some more advices, tips or comments ?
Thanks!
https://www.sau.com.au/forums/topic/197679-a31-alignment-settings/
How thick are your sway bars? My front one is 30mm solid, and I feel its too thick, and is partly to blame for the outside of my front tyres getting scrubbed out.
That's not particularly logical, less roll (bigger swaybar) would mean less wear on the outside edge of the tyres. More logical would be insufficient caster and camber or excessive toe in.
Cheers
Gary
Thanks!
Swaybars, adjustable of course. 27mm front and 22 mm rear for grip, 26 mm rear for drift
Spring rates, 275 lbs/inch front and 225 lbs per/rear
Shocks, the best you can afford, Bilsteins are the best value for money (forget Jap shocks entirely)
Alignment settings;
Front
Height 345 to 355 mm
Toe = zero, if the turn in is a bit reluctant try up to 2 mm toe out each side, learn how much adjustment you get from each turn of the adjuster
Caster = as much as you can get for grip, around 7 degrees for drift
Camber = make sure you can adjust between 2.5 degrees negative and 4 degrees negative. Then use the pyrometer to tell you how much to run. Use the offset pins in the upright to get the 2.5 degrees negative, then the adjustable strut top for quick changes at the track.
Rear
Height = 340 to 350 mm, adjust the rear height to achieve the desired weight transfer to the front outside tyre
Toe = zero for grip, 3 mm toe out for drift, learn how much adjustment you get from each degree of rotation of the adjuster
Camber = make sure you can adjust between 1.5 degrees negative and 2.5 degrees negative. Then use the pyrometer to tell you how much to run for grip. Use the wear rates to tell you how much to run for drift. Quick adjustment of the rear offset bushes is essential.
Subframe angle = the "all round" setting for grip on the subframe alignment bushes, obviously the "drift" setting for drift.
Diff, a Nismo externally adjustable, 1.5 is the best considering the two disciplines, that way you can change the preload. You want the diff to unlock on turn in for grip, but not drift.
That should get you started.
Cheers
Gary
Cheers
Gary
Cant dissagree with your logic, as its most probably correct.
But its got about 2* toe out, 5-6* castor, and about 1.5* camber... So we'll have to put it down to camber. Its going in for a wheel alinement on tuesday, so I'll get the settings you posted above done, see how I go with that.
That said, my logic was if the car cant roll, its gotta go somewhere, so if the car cant roll over a bit to lean on the tyre, it goes somewhere else, being to the edge of the tyre. So maybe its somewhat to do with tyre pressure too. I havent had much sleep this week tho, so it probably doesnt make sense to anyone else.
Could also be worn bushes, particularly the lower inner. It won't hold the static alignment settings if they are worn.
Plus if its too low (less than 350 mm), it will have dynamic camber change ie; that negative you have static will dissapear when the suspension is compressed. I have seen too low R32GTR's actually go positive camber with only 60 mm of spring compression.
Cheers
Gary
Well I got mine done today, seems my issue was 6mm total toe out on the REAR. Also my front left camber adjustment, the nut is shagged or something so they were unable to adjust it, just no other place decided to tell me that. So its been sitting on -0.6* camber for the past 12 months... Which would explain a lot.
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
