the GFB Stealth-fx does what you want.......................
Apparently it doesn't... as it's only 50 50 plumb back... if I plumb it all back then same thing as stock.
Thanks.
It does
I bought one for CHEAP a few months ago, its on my auto mod'd stagea atm.
stnd bov got "repaired" :D
and now that Im on holidays, as of like 1hr ago, Im going to take off the FULLY ADJUSTABLE gfb stealth-fx bov (worth $550 new)
and put back my fixed stnd one
my mack truck is about stealth not sound
contact me if you want it for what I paid for it
I used it on full plumb back and full spring tension, works real nice and sounds, well, funny.
a few test runs would sort out what sort of atmo / pmub back percentage mix works on your car
its not my kinda thing, I got it to hold boost pressure, but Im going about that little quest a different way now so I have no need for this as of next week.
but if you are into bov's, then the GFB stealth fx is worth a research matey
  • Replies 149
It does
I guess, I'll just leave it on Stock then... I can't be bothered, BOV's are so expensive, and the sound that I want is really hard to find... some, e.g. WRX BOV's sounds like a pigeon on steroids... sounds so ghey... I guess, I'll leave it stock... who cares....
Cheers,
you all need to attach a duck call whistle to the end of your blow job valves.
it will solve everything.
ssss quaaawawawawawawa
I gues there's nothing we can do then... Heard you can modify the stock on to make it sound better, but apparently not a good option... never mind... thanks.
god there are some dumbshits on here
ok here i go
stock r33 bov which is NOT PLUMBED back so its running into the atmosphere ok
car runs on map sensor and i dont have all the stock plumbed back piping shit so i ran it atmosphere
bov leaks like a heap of shit,must i explain myself any fkn further or are u just another keyboard warrior wanker on here who pays every other c**t to do shit on there car?
thanx good day
lol well your the dumbshit who is running a plumb back BOV to atmo?
If you had half a clue you'd know the stock plumb back setup returns air into the intake pipe to keep the idle stable when dropping from various RPM.
And you'd also know it circulates air through the plumb back setup to keep gear changes smooth while driving (prevent surging).
Now it does leak air through, but because its plumbed back it all goes back through to the same place in the end.
Link below also shows the fact that the stock BOV DOES leak, is you make it ATMO it will leak into no where.. = loss of boost = loss of power
http://www.skylinesaustralia.com/forums/St...l=stock+r33+bov
So if you don't plumb it back, of couse it will leak idiot thats why its plumbed back in the first place..
Now which moron reroutes a plumb back BOV to ATMO?
Your the dumbshit who has hooked it up wrong, now you blame the quality of the stock BOV saying its shit and doesn't work?
Basically there is nothing worng with the BOV, just your stupid setup.
If you had hooked it up right it would run perfect but because you have hooked it up like a retard it clearly doesnt work.
AND I wasn't having a go at you, all i was saying is that what you stated was incorrect.
The stock BOV will leak when not plumbed back because thats how its designed to work.
Your the one who got abusive :)
Edited by abu
I think CEF11E was runnnig like 19psi on stock R32 BOV with no leaks and this dumbass reckons his is leaking.
Probably not even running close to 19psi either.
THE MAFIA is always saying he is running 20psi with a GT3076 making 300rwkw on a stock BOV with no leaks..
Are you making more than 300rwkw buddy? You must be if your BOV is leaking that bad!
Keyboard warrior your self wanker.
Edited by abu
i was running 1.3 bar thru the stock bov you f**kin wanker... both atmo and plumbed back and either way it fkn leaked. dont try and tell me whats right and what wrong i KNOW what it does and i KNOW how it works im stating what it was doing and ill stand by it. dont need someone like u to tell me otherwise lol
What Abu said is correct, I done some research and have spoken to a few people at Chaser Motorworks - the way a R33's BOV works is based on a setup that the BOV is plumbed back into the intake pipe as the engine expect this - without this setup (e.g. atmospheric blowoff) then this will muck up all mixtures and settings hence stalling...
I have to say, I love the Pphsshhttt sound, but if it means non-stop stalling, I'd rather not have the sound so that my car rounds smoothly... but I agree... the stock BOV works perfectly and does its job - don't fix what aint broke... I mean, I'd love to have the ppsshhhttt sound if it's full plumb back but don't know if there's such a BOV that works this way....
Guess getting both the sound and preventing stalling is impossible
Thanks fellas...
Also, what's the difference between a Stock R33 BOV and the following?
Which would host boost better?
Which would make better sound and would both be as good?
Cheers,
http://cgi.ebay.com.au/SKYLINE-R32-R33-R34...1QQcmdZViewItem
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
