Well last night we went for a bit of a drive down the coast, on the way home I noticed she was sounding a little funny, then when I went to put the foot down she was definately sluggish and the boost just wasn't there. It got home alright, i opened up the bonnet and there was definately some funny noises (rattle/clicking) coming from the turbo, then I went back and stuck my head up behind the car, and there was also a bit of a rattle coming from the exhaust somewhere, couldn't exactly pin point but definately sounded like there was something in there.
Am I right thinking i've done the turbo wheel ? It's sunday and I can't really do much till tomorrow.
https://www.sau.com.au/forums/topic/1978-blown-turbo/
I don't know if it's blowing any smoke, it doesn't really bother me THAT much as I was looking at getting a new turbo anyway, but now i'm not sure if I wanna rebuild mine, or whether i'm gunna get a VG30 or what. Looking at something cheapish but that's gunna reap some decent performance gains.
https://www.sau.com.au/forums/topic/1978-blown-turbo/#findComment-36991
