Hi everyone, i was wondering if anyone here can tell me the difference between the series one and series two seats besides the different trim material? This is because lm getting some leatherette seat covers as a gift but its suited for a series 2 when l have a series one. When l tried contacting the manufacture, he was extremely unhelpful and just suggested l buy a new set from him instead of telling me what the differences were.
Thanks Everyone!
When i got my set, i didnt think i stipulated the year of manufacture or the series.
I didnt think the interior would matter when it comes to seat covers, even the tight-fitting leatherette ones.
lm only asking because someone told me they were different but i didnt think the guy was knowledgable enough in Skylines to get a definite answer =D
Hence the question is asked here.
Cheers
differnt fabric, same style.
