Well for the past two weeks my car has had this problem... At first I thought it was the AFM, so i checked it with 2 different ones to no avail. So o then thought it was a connection problem in the loom plug, but last night, Me and Hippy tested all the connections with a multimeter and we found that they were fine (eventually).
So now im at the stage to think the ECU is buggered :D So ill be trying a new one tomorrow to see if that fixes it.
However what has got me really confused is that sometimes the car runs fine, revs perfectly, and about the other 95% it runs like crap. Could it still be the ECU even though the problem goes away and comes back???
Sooo confused....
https://www.sau.com.au/forums/topic/19805-help-car-wont-rev-over-2500rpm/
Well i went to see Boosted (member from SA) and we found the problem, faulty plug, aswell as a maybe fried ECU.
Will find out on monday or tuesday whether the ECU is fried... Diagnostic comes up with AFM circuit. ITs not the AFM, its been changed 3 times..
Hehe cleaned it many times with contact cleaner. Guys its a biggish problem. The last 2 weeks its been happenin ive tried everything. Thanks for your suggestions...
I have no idea how the ECU may of fried....
My logic to this is: Today tried a new ECU, the car still didnt work. We then put pressure on the plug which connects into the AFM, and the car would be good, take pressure off and its stuffed again.
So then i put my original ECU into the car and put pressure on the plug and it wouldnt work...
So yeh thats why we think the ECU is buggered aswell.
I had a strange thing happen with my AFM quite some time ago when the FMIC was fitted.
When first starting her up she was lumping as if it had a huge arse cam in it.. Lots of black smoke out the arse end.
Tried to rev her up and it was a real flat not wanting to rev type rev. Pulled the AFM off put it back on and did the same.
Slapped a R33 AFM on and it was perfect no problems. Then after the tune we slapped my AFM back on and it was ok.
My guess was a dodgy plug.
Yeah theres something about those plugs cause that power steering fluid prob was not the only one I had. I almost felt like it had a wire loose inside. Fortunately i have not had a problem for some time now......................touch wood.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
