I have a question regarding imports without logbooks. Are they common? The dash has been changed but the actually mileage has been recorded down on the auction sheet. Anyone thinks this will be a problem? I have arranged the car to be checked by a third party company. Its a dealer's car btw. Hear some good stuff regarding this dealer from Mark Hocking too. I just want to know is it normal to get a GTR without logbooks or not.
Cheers
https://www.sau.com.au/forums/topic/198096-logbooks/
These days it seems like most dealers will try and find imports that have logbooks and import those as they have a higher resale here in aus, as alot of people prefer to buy a car with some retained history.
Ive personally bought imports, cars with out logbooks before but they wer older cars. My S14 Aussie Spec has logbooks.. My R34 GTT dusnt have the japanese log books but has the import papers etc with kms etc.
Can the R34 digital meters be tampred with easily? Would they even bother doing it..?? On GTR or something i can see why they would but..
https://www.sau.com.au/forums/topic/198096-logbooks/#findComment-3538457
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
