hi guys.
Ive recently had my steering rack rebuilt cos the steering was crappy. The steering is still crap. Im now looking at getting the pump rebuilt but i dont wanna leave the car at the mechanics and walk around for a week while im waiting on it to be rebuilt and replaced. A mate of mine has 2 spare S13 pumps that he doesnt need anymore. The question is,
Will an S13 power steering pump replace an R32GTR power steering pump?
Cheers, Ron
https://www.sau.com.au/forums/topic/198352-power-steering-pump-r32gtr/
Running HICAS still?
Locking it up, and pulling the solenoids can feck with the HICAS control unit. Some say more caster can iron this out. Tomei make a box that can intercept the unit and stop the steering from going heavy. Ppl have jimmied the solinoid on the rack which adjusts steering assist.
Define "crappy"
Edited by GeeTR
the hicas has been completely removed including the solenoid. the line to solenoid got plumbed into the power steering cooler located next to the drivers side head light.
"crappy" steering feeling is when turning a corner in either direction the steering could be light and heavy numerous times in the 1 turn. so light heavy light heavy light heavy.... like the steering is fighting against me but not in a natural way.
i spent almost 45 mins talking to the director of the company that rebuilt the rack and we came up with the idea that maybe there is sticking valves in the pump which is restricting fluid to the rack. this would explain the intermittent feeling and also explain why the steering sometimes comes good. it could also explain why the rack needed to be rebuilt.
i cant remove the hicas ecu as its the same ecu that runs the 4wd. whats the hard/soft solenoid on the rack? Trent are you talking about the hicas solenoid right? thats been removed along with the lines to the rear steering rack when the lock bar was fitted.
I think you might be a tad confused.
The hicas ecu controls the hicas and the power steering.
The ets module controls the abs and 4wd.
There is a solenoid on the front power steering rack almost directly under the drivers feet that modulates the power assist for the steering. Check that the wiring to this is still good and that you are getting a voltage there at idle.
*edit. Perform a hicas diagnostic and see if there are any faults evident. Power steering goes hard when there is a fault with the hicas system.
Edited by heller44
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
