Hey again,
Buying a 33 GTR and my choices so far is a Standered car but perfect condition inside and out and a bit more expensive, or a slightly moddied car but rough inside and out but a bit cheaper making 260kws.
Just wondering though, what sort of kws do stock as a rock GTR 33s put out?
And if i buy
Power fc
Boost controller
FMIC
Full exhaust
What would that up it to roughly?
That would be a huge help
https://www.sau.com.au/forums/topic/198416-r33-gtr-power-output/
I don't know why we need another thread on this.
Expect around 250rwkw on standard turbos with a Power FC, small boost increase and an exhaust system.
A bone stock R33 GTR puts out around 160awkw
Upgrading the Intercooler will be a complete waste of time and money at this power level on a GTR.
My advice, buy the dearer and better condition/unmolested car to start with.
THAT ALL! 160???
but with $2000 it should hit 250kws?
Will the standered clutch, fuel pump and injectors still be ok?
THAT ALL! 160???
How long is a piece of string? If the standard pump and injectors are in good working order, they will be fine.
As for the clutch, be prepared to replace it.
Where did you pull the figure of $2000 from exactly? Thats a tad unrealistic for the mods list you mentioned.
Excellent thanks mate...
What sort of clutch would be enough to hold around the 275kw mark mayb 300 eventually as i may replace turbos?
price?
And if i buy
Power fc
Boost controller
FMIC
Full exhaust
THAT ALL! 160???
$2000 for those mods? you might want to research that.
I see.
Power fc - $1500
Boost controller - $500
FMIC - waste if time the stocker is good for 300rwkw
Full exhaust - $1500 (2 dump pipes, front pipes, cat, catback
Add clutch - $800+
Add install - $500
add tune - $800
I see.
Power fc - $1500
Add clutch - $800+
Add install - $500
add tune - $800
yer your right.... was just talking about buying boost controller and power fc... i was under the impression that power fcs for GTRs were a bit cheaper
APEXI no longer make POWER FC.
they are ALL expensive.
and the boost controller for the PFC is not built in so to speak.
you still have to buy the device that will do the boost controlling.
it attached to the power fc which then allows you to make changes to boost via the hand controller.
ahhh so you have to get the apexi boost controller to make it work with the power FC?
Picked up a GTR Power FC yesterday brand new $700. But normally they average $800.
As for boost control i think u can just remove the restrictor in the vacuum line....maybe do some research on that. The money u save on a boost controller u can put towards tuning.
where was that from??
Adam mate, use the search button dude. People have taken the time to post all this info before. So do them some justice by reading it.
You've been here long enough to know where it is, and how to use it :)
GTR PowerFC's are still sold at ANY importer or parts distributor. GTST is wrong with his info.
For power output, check the Dyno sticky thread.
There are a dozen results, if not more for a basic modded GTR. They are not going to be magically different to yours.
Cheers.
Guest
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
