That's interesting.........I've got some -5's ready to go on with a PFC, full fuel, cams and intercooler upgrade so I'm hoping to pull at least those figures myself. Oh.....and a Kakimoto full dual N1 exh.
Did you have to do many other mods to get those figures?
Hey mate, Had the supporting mods like 550cc injectors, 040 pump, FPR, Power FC, full 3'' exhaust with "high flow" cat and trust cat back, Car also has R33 GTR engine. With the -5 you should get around 330-340. I chose the -7 as I wanted really good response with minimal lag, at the moment it feels like the -7 spool at the same speed the stock turbo's were.
Ryan
https://www.sau.com.au/forums/topic/198423-tuners/page/2/#findComment-3545073
hey i have found a GTR i like now im wanting to get a quick check over it before i buy. but boostworxs is packed out and unable to do it...
Who else would you find reptuable to look over it, compression test it etc????
PLZ need this ASAP
https://www.sau.com.au/forums/topic/198423-tuners/page/2/#findComment-3545080
you'll struggle to find someone this time of year but I guess just call the regulars.
morpowa
tilbrooks
graham west
jaustec
willal
If your just after a compression or leak down test then any workshop can do that but I would personally go somewhere performance orientated and get them to check the whole car over....when GTR's brake there not real cheap to fix.
Ryan
https://www.sau.com.au/forums/topic/198423-tuners/page/2/#findComment-3545093
morpowa
tilbrooks
graham west
jaustec
willal
Ryan
yer thats what i mean after someone to go right over it and know what to look for... eg boostworxs!
https://www.sau.com.au/forums/topic/198423-tuners/page/2/#findComment-3545103
Yes, His buisiness is called Fuel Automotive. He is a qualified diesel mechanic but has done alot of work on at least 3 R32 GTR's from this forum that I no of, including turbo swaps/suspension work, he also owns a GTR so basically he knows what he is talking about.
Ryan
https://www.sau.com.au/forums/topic/198423-tuners/page/2/#findComment-3545532
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
