Hi ACT guys and gals,
I'm looking at getting rid of my spacers in the early new year and have found some replica GT-Cs on Tempe's website. They are 18 x 7.5 with a +31 offset or a +40 offset.
http://i219.photobucket.com/albums/cc266/EMPIREAERO/GTC.jpg
Does anyone know if these will fit ok on a R33 GTST without the need for spacers on the front or rear?
Cheers
Sam
https://www.sau.com.au/forums/topic/198454-new-rims-sick-of-spacers/
Cheap rims are normally heavier, as they are made of different type of alloy. Due to the mass of the rim, it takes more torque to get moving (slower acceleration), more difficult to turn (something to do with centrigual force). Because of the type of alloy, the rims are less forgiving to incidents and seem to crack, rather than give.
Yeh, i understand that cheap rims are a lot heavier and not made to the same quality, thats why they are cheap. I already have some Volk Racing GT-C's on the car which I will use for the motorkhana's, hill climbs, wakefield...
I don't exactly plan to have an incident in the car (as most people wouldn't), and yes, i know stuff happens.
I'm keen to buy these http://www.skylinesaustralia.com/forums/Go...De-t197378.html but I'm not going to lay down the money until I can guarantee fitment without spacers. Its a lot of money to throw away otherwise... Can anyone confirm it asap so I could make an offer to the guy?
(Sorry guys, i'm not disagreeing with any of you, I just figured cheap rims for around town aren't going to be so much of an issue. But as you say, throw more penny's at rims for quality, I will, if ^^ these ^^ fit, i'll buy them now)
Hey Sam,
These wheels should be fine for an R33 Gtst, being an 18x8 35+ and 18x9 38+ they should sit very close to where the standard rims would.
If the rears were 40+ they would be better but being 38+ just means that they will sit further out by 2mm (not much really) :rofl:
I dont see there being an issue with clearance of either guards, brakes or inner guard covers.
In saying that I never recommend buying wheels that you arent able to test fit first, but that may be a bit difficult in this instance.
You will need to do a bit of research on the best tyre fitment though (I can help you there).
If it were me, I would buy the Volk's not the cheaper imitations. :)
Edited by Bullet32
Oh ok, I read the thread wrong, sorry.
I would ask if they have been on a GTst before, but I dont see them being a problem.
They will sit a fair bit further out towards the guards than the standard rims - you will have an extra inch on the inner and outer of the rears over a standard GTst wheel.
The fronts will be slightly less than a half an inch on the outside and slightly more on the inside over standard.
The extra O.D. (overall diameter) means that you will need pretty low profile tyres, but that shouldnt be a problem... I would say - 235 / 40 R18 front and 265 / 35 R18 rear.
:rofl:
Hmmm....wouldn't that mean the OD would be smaller on the rear?
Not neccesarly... You cant compare tyre O.D's from one tyre brand to another because they are only relative within their own brand.
The Federal 595's in 235 / 40 R18 have an O.D of 642mm
and the same tyre in 265 / 35 R18 is 643mm
Not one tyre brand has exactly the same measurements as another because its not an exact science.
Edited by Bullet32
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
