Wed Night Drags Next Week - Anyone Going?
Just wondering if we have any of the SAU guys heading down to the plex this Wed?
I am heading down to help introduce a friend of the family to the right place to go racing either with his newly purchased R33 gtst or my bunky R32 GTR.
Be good to say g'day to any of our fellow skyline crew. :thumbsup:
Should be getting cooler as the evening sets in regardless, the forcast was for high 30's.
Will say g'day sidewayssam if I see you, I will either be there with a mate of mine and his R33 (blue colour with a large wing) helping him with his first time at the drags or in my bunky R32 GTR. The GTR is midnight purple with tiny stock R32 gtst rims and no wing.
i think its gunna be around 40, definitely no good for drags. I'm looking at going on the 9th with a few guys if interested (weather permitting)
Temp will drop down to mid/low 20's by the time you need it to. If you have traction issues then the lower power due to ambient temps being higher earlier in the night can help you get a handle on things before power jumps up later in the evening.
As a result some of my better times over the years on crappy street tyred cars have been done when the mercury has been in the mid to high 30's.
Edited by rev210
yeh usuall i drag dads ss and at the start of the night ill be runnin low 13s but when it really cools down at end of the night im usually in the mis 12s it will be interesting to see what the skyline runs tho, what kind of time do you guys run? im hoping for a mid to low 13sec
If you have some decent tyres (deflate the ones you have for better launch) then you should be into mid 12s pretty easy, I noticed you have the better part of 300rwhp.
yeah i'll might be there trying to hit a mid 14 with my mostly stock skyline i got a FMIC, exhaust and a pod, last time i went i got a 14.9 but with a 0.7 reaction time.
If the pod is unsheilded, it's probably part of the problem. reaction time doesn't effect your 1/4mile time by the way. Reaction time is the time it takes for you to break the beams after the green light. Once the beam is broken (ie: your car is moving forward) the time for you pass starts.
Your 60ft time is a good indication of how well you are launching, a 2.1 sec or better time is what you want to try and get.
Will try and say hello , what does your car look like?
Edited by rev210
hey mate,are you running mid 13 on stock turbo?
Edited by flake32
i havnt run the skyline yet, im hoping for a 13, nah its got a hks gt2540 turbo runnin at 14psi. ive heard that the gt2540 is a pretty crap turbo and wont really go any harder so im looking to change to maybe a kkr480 or sumthin
oooo did not know that about the reaction times, my car is a red r33 gts looks pretty stock with stock rims, im gonna try to do some work to it over the holidays.
I did consistant low 13's years ago with an R33 gtst, not very hard. You can get into 12's if you run decent tyres.
That was with the stock turbo at 10psi / stock intercooler / stock ecu with a S-afc II /lightweight flywheel and turbo back exhaust. On tiny 205 stock sized tyres.
Edited by rev210
bro nuthing wrong with the hks,it might not make huge numbers but is responsive and good quality,ive been thinking about kkr myself but turbos that cheap?, there has to be sumthing wrong with them,if i spot your car tonight il come say hello,ps you wana sell 2540 let me know il slap it on my rb20,
my last car was r33 with the same mods,,and the best i got was 14.2,after like 10 runs,never tryd letting tyres down tho,might give that ago with my 32,ive noticed over the last couple of weeks most stockish r33s struggle to even get mid 14s,and most 32s are even slower than that,makes me scared to think my 32 might run a 15,no!
I'll probably head down in a couple of weeks to benchmark the 30+small turbo before my baby comes off the road for the GT35R install :)
I'd be hoping for a low 13! but who knows.. will be interesting to see what the 30 does with the 3.9 ratios..
Makes 245rwhp @ ~4600rpm on 12psi (full boost by 2200rpm).. anyone like to take a guess on what it might do down the 1/4?
Edited by bubba
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
