Same reason you see burnouts up hills.
Those with pissweak cars need a 'chock' or hill to do a skid otherwise they don't have the power.
1 strip usually ensues.
These are what we call "sikkunts", often found in low-economic areas such as kwinana/balga.
ROFL @ maccas trays!
When I used to live in scarborough years ago (before they closed off half of that street that goes up the hill at the end of the carparks), someone in a Swift dumped 20L of oil at the bottom of that hill and ALL night idiots were lighting it up up the hill, got to the point where the cops came out and sat on the median strip with the lights going all night.. highly annoying as it was RIGHT OUTSIDE OUR BLOODY APARTMENT!
That was a ritual for decades before the appartments were built.
Scab's burnout night, every weekend. Features include:
* police riot vans
* A demonstration by the council sand dumping ute and it's dare devil team of on-call workers.
* both red and yellow stickers
* people showing their tits (including the rare female)
* People running around a car park with car jack
* slots of blown tyres that look like the ones you left at the tyre place the day before because they were bald.
* cars driven by drivers without a licence doing a burnout
* unlicenced cars doing a burnout with drivers who still have a licenece but, are about to lose it
* unlicenced cars driven by unlicenced drivers doing burnouts
* Unlicenced monkeys driving unlinced uni-cycles doing burnouts
* people giving the signal and saying things like 'arc it up mate'
And many more exciting events.
All sounds like a standard firday nite in Nowra, they have a chemical factory so there chosen traction suppressant was pink detergent.....
Clean your wheel archs at the same time...
Yepper
the local 1/4 mile was out the front of the RTA...
saw my first ever drag race there, guys with torchs at the finish and start on the flash of tits....
miss those days. maybe 1987 or 88
sounds like you've spent some time there as well
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
