Rb20 Power Proplems
TOSHI, CEFFIE on these forums.
Can both do this sort of shit for these sort of dollars.
the fact is, if it's using stock Injectors, stock AFM, they can use one of their generic chips that they would have.
I'm sure both have the ROMs to match an RB20 with (eg) 12 psi, stock injectors, afm and stock turbo and then another which has the above but with rb25 turbo... etc..
and they can both remove the speed limiter and raise rev limit if you want..
Just drop the guys a PM and ask some questions.
they are both very heplful
  • Replies 49
Guest trikdoutvl
huh... i dont have a speed limiter
on a unrealated note....... do all skylines have a beeping alarm when 1 of ur indicators stop working?? cause my indicator stopped workin n when i put the indicator on the car starts beeeping, neva didd that before i had the rb20 motor
Hmm that’s interesting.
Wonder why the auto had it but not the manual, maybe just as a warning as the auto wouldn’t stall like the manual if you accidentally put it in reverse and forgot about it.
I think I vaguely remember my cousins 93 R32 auto having a reverse beeper thingy...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
