master controls? or the relay module?
i have a set of master controls for a 1994 R33 (so if you have a S2, no good to ya, loom is different) but only the passengers side window switch works... so a bit useless yeah.
if its the relay module, try looking in the Tutorials/DIY forum. There are threads on how to repair faulty ones. All you need is soldering gear basically.
some of the wreckers may be open tomorrow. Check the SA wrecker list sticky thread in this forum for their details, and ring away
Edited by MSPEC33
if u got an r33 series 1, u gotta buy 2 parts or know someone that solders...
if u got an r33 series 2, u gotta buy 1 part expensive f**ken part at that. (uless ur llucky to ebay it. i got my control module for 60 dollars off ebay and a window motor assy off ebay for 50.)
if you think you need a new switch pack, ring these blokes:
Import Spares, 8266-0212
2 Sleaford Road, Windsor Gardens
http://www.japaneseimportspares.com.au/
I bought one from them a few months back. They had quite a few in stock.
Just make sure you bring your current one in and match the looms, because either they are either different between series 1, and 2 models of the R33, OR there are other model Nissans out there that have the exact same switch packs -just different looms.
cheers mate ill give them a call!
  • 1 month later...
the way round it would be to cut your current loom from the wires and rematch the wires to a loom that will fit the switch pack you have...
BUT dont quote me on that. They are probably shaped different for a reason / hence, the above idea i mentioned may not work
Edited by MSPEC33
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
