Item: 6 X 480cc injectors from JDM manual s15
Age: from 2001 s15
Condition: great, flow tested and cleaned
Price: $400
To Fit: (What car) any with rb25det non neo.
Contact: 0401723975
Comments: was going to drop them into my engine but plans have changed, regretful sale.
2 injectors will need some O-rings
the other 4 are still sittting in the s15 fuel rail.
Edited by eddieeeee-ro
https://www.sau.com.au/forums/topic/199645-sold/
well most will say 480cc is good for 250kw with 80% duty.
so i guess if ur running stocks this can only be better?
btw i wouldnt run the stock injectors @ 100%
https://www.sau.com.au/forums/topic/199645-sold/#findComment-3558969
Yeah thats true. Imagine getting just a bit of build up in the injectors due to a dirty fuel filter or bad fuel = ping ping ping.....
https://www.sau.com.au/forums/topic/199645-sold/#findComment-3563060
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
