I used to run 235/45/R17's on my GT-T. I would not say its the best choice, if you're looking for good cornering/responsiveness etc. but it did make driving the car feel nicer on highways etc, uno, when you're just taking things easy. The GT-T still cornered great in my opinion, but I never really pushed the car too hard.
https://www.sau.com.au/forums/topic/199695-r34-stock-rims/#findComment-3564022
Currently running Federal ss595 in 225/45/17 on the front of my car, fit the rims quite nicely, sit nice and square and handles very nicely (also don't look as ghey rolled over as the same size/different brand tyres on the back).
Going to try squeeze some 245's on the back when I need new rear tyres..
https://www.sau.com.au/forums/topic/199695-r34-stock-rims/#findComment-3573862
  • 3 weeks later...
If I'm running 19x8.5 for the front rims what would be the safest tire size? 225's? I don't want to sacrifice turning ability or scrub or have to modify anything. And my rear will be 19x9.5... I'm hoping to be able to fit 265's without scrubing or work.. is it possible?
https://www.sau.com.au/forums/topic/199695-r34-stock-rims/#findComment-3615202
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
