Hey everyone,
I was just wondering if anyone bought this skyline that was on carsales the owner says it was sold. Just wanted to find out who as it and if they are willing to sell it to me?
Thanks
http://www.carsales.com.au/used-cars/priva...=2&__Nne=20
Edited by Sonic speed
https://www.sau.com.au/forums/topic/199799-wanting-to-find-nissan-skyline-gtst/
Ring the original owner ask them to contact the new owner and give them your details.
If you dont get a call then they didnt want to sell it, if they do then you do...
Trying to find it this was is impossible.
