hi all i have a r33 with the standed r33 thermostate in it , what im after is one that opens around 62 degand not a 150 buck nismo one surley there must be something that fits . any help would be great ive done the search thing without much luck .
cheers dean
https://www.sau.com.au/forums/topic/199847-themostate-temps/
nismo themostate is the best!!! and good price
150 bucks is far to dear for a 62 deg thermostate just cause its got a nismo sticker on im not paying for wank value .
im sure there are other 62 deg thermo made by other companys that will work exactley the same . i dont see nismo thermostates stuck in every nissan ever made. i will go thru the catalogs from our suppliers when im at the workshop next
Why do you want a 62 degree thermostat? That's too low a temperature for maximum power or minimum engine wear or maximum fuel economy.
Cheers
Gary
cheers for that gary
i thought if i got one that opened a bit earlier it might help with my cars prob of running to hot in hilly areas on 40 deg plus days . how ever i just pulled my old one out and stuck it in a saucepan on the stove it did fully open but the water was almost boiling b4 it started to move at all .
so i suspect the one thats in there is not playing the game right atm it is a standed nissan one 76.5 so i think i will replace it with the same type as the one i just pulled out
thanks for your advice
cheers dean
Cheers
Gary
gary, what is the best temp? I am getting a constant 91 deg, doesn't matter how cold it is outside... and on hot days it goes up to ~95-98... I am used to my other car running at ~80deg, what is optimum for the stag?
-Ryan
-Ryan
Ours usually runs mid 80's normal driving and high 80's when pushed. Time for a radiator flush perhaps? Or maybe a debug, ours was a bit clogged with dead insects last summer.
Cheers
Gary
Cheers
Gary
sounds like it... was planned for next service, but might have to do it sooner... i sent thru a PM for matt BTW
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
