hi all i have a r33 with the standed r33 thermostate in it , what im after is one that opens around 62 degand not a 150 buck nismo one surley there must be something that fits . any help would be great ive done the search thing without much luck .
cheers dean
https://www.sau.com.au/forums/topic/199847-themostate-temps/
nismo themostate is the best!!! and good price
150 bucks is far to dear for a 62 deg thermostate just cause its got a nismo sticker on im not paying for wank value .
im sure there are other 62 deg thermo made by other companys that will work exactley the same . i dont see nismo thermostates stuck in every nissan ever made. i will go thru the catalogs from our suppliers when im at the workshop next
Why do you want a 62 degree thermostat? That's too low a temperature for maximum power or minimum engine wear or maximum fuel economy.
Cheers
Gary
cheers for that gary
i thought if i got one that opened a bit earlier it might help with my cars prob of running to hot in hilly areas on 40 deg plus days . how ever i just pulled my old one out and stuck it in a saucepan on the stove it did fully open but the water was almost boiling b4 it started to move at all .
so i suspect the one thats in there is not playing the game right atm it is a standed nissan one 76.5 so i think i will replace it with the same type as the one i just pulled out
thanks for your advice
cheers dean
Cheers
Gary
gary, what is the best temp? I am getting a constant 91 deg, doesn't matter how cold it is outside... and on hot days it goes up to ~95-98... I am used to my other car running at ~80deg, what is optimum for the stag?
-Ryan
-Ryan
Ours usually runs mid 80's normal driving and high 80's when pushed. Time for a radiator flush perhaps? Or maybe a debug, ours was a bit clogged with dead insects last summer.
Cheers
Gary
Cheers
Gary
sounds like it... was planned for next service, but might have to do it sooner... i sent thru a PM for matt BTW
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
