Rideout For Sauers With Motorbikes - New Date Discussion
Due to popular demand I am organising an SAU ride out on Saturday 19 Jan. We will meet at the Krispy Kreme carpark at Liverpool at 10am for a 10:30 departure. Regroup at the carpark just before the entrance to the National Park. If this is full of soccer mums, as it sometimes is, then just go around the corner to the first carpark off the National Park road. Anyone who doesn't want to meet at Liverpool can meet us there at say 11 to 11:15.
After this we will go through the Nasho and have an earlyish lunch at Thirroul. From there we can decide where we want to go. I usually go on to Mac Pass but it's probably too far for newbies or L platers. Newbies cos your arse will be sore and L platers cos there is a bit of fwy which you can only go 80km/h on.
So post up if you're coming.
EDIT****
Date changed to 19 Jan.
Adam said Livo and KK in the same sentence.....something I thought I'd never hear.
so this is what is come down to......our el presidente defecting to the biker group...ha ha ha
hope you guys have fun.
adam is it just SAU bikes invited? ive got a few mates from work and a couple of mates that i always go riding with... good group of people... would they be able to come if they could make it?
im not working on that saturday abo, so looks like im in, and more than likely ill have a gixer, R1, 2x620 dukes and maybe an MV Augusta, whatever the Yam 1000 is, and whoever else from work wants to come... ill confirm the numbers closer to the date
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
